Turn off frame around detailed view.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Basically all in the title. Why can I not turn this off (technical reason please). There are many reasons why you should be able to turned this off, and I am sure many reasons for having it. Yet I have had clients (and bosses) asking "whats this edge?". Well, I tell them, its a line I can not turn off (unless I want to turn the whole layer off which removes all break lines in the entire drawing). If you right click on the detail view box/circle on the main view and go to options you can select 'smooth cut out shape', Which puts a thick black line around the detailed view, select 'full detail boundary' which seems to make the line thinner and it highlights when hovered over (but you can not turn it off) or have a jagged line which most of the time just ends in a mess where there's cuts and jagged edges into the view obscuring things that should be visible. It's possible to turn off cropped edges. I have gone so far as to try and crop a detailed view so I could get rid of the lines but obviously inventor does not allow you to crop a detail. That would be a stupid work around anyway. So my current work around is to import a copy of the base view, crop it down to what I want as the detail, label it as 'Detail X' then sketch a box on my original base view corresponding to to the crop I have just made and add a leader to this sketched box saying 'Detail X' which I am sure everyone can see is an awful thing to be doing.
If any developers read this please can you go in to detail as to why this is not possible? Not just say it's not possible at this moment, as I've found people asking similar things to this from over a decade ago. Is it because a long time ago it was decided that the detailed view boundary and brake line are the same object and now its so tangled in the code that it is seen as too much work to separate?
Just to be clear I am not asking if this is possible, I know it's not. I'd like to know why it is not possible and has not been implemented.
