How to create a scaled a part of a projected sketch the same way I can create an offset copy of it?
Lets say I do have a projected piece of a sketch, like a yellow solid lines on below image:
Those lines are in fact driven by some parametric engine, projections and etc. and may change dynamically since this sketch is a part of a parametric part. Thous scale and offset is also solved through many projections and computations.
Now I need to create a scaled and moved "clone" of this piece of projected sketch geometry. I can do "offset" clone with "offset" tool which will nicely follow changes in primary shape. This is an excellent tool.
I can't however figure out how to do it with "scale" and/or "move". The good example of what I need is Inkscape and it's "linked clones".
Breaking projection links, manually drawing an identical shape and anything what would break an automatic update path is out of question.
Can anyone point me to an efficient path of doing it?
