Hi all,
I am working on pipe routing where I am able to use tube and pipe option from inventor 2022
Here my question is I want to create single route with 3d sketch and derive pipe routing based on sketch which is positive by derive route but I want 3 pipes with certain distance parallel to each other which are routed with one single common sketch route is it possible
Just like bunch of cables routed
Please find image i am expecting this kide of pipe routing with one single routing sketch common for all there
Hi all,
Any updates on above question
No this will not work.
@vishnuteja14 I think what @johan.degreef is talking about is that you can not have pipe touching like that, unless there are no flanges in the system. Or maybe he means that T&P won't allow touching pipes...? "However" if all you are trying to do is route those runs which will fan out to allow flanges or each turn off to allow fittings than this is easily done outside of T&P.... do you have to use T&P?
This might not be possible or at least not easy. Just trying it is the easiest way to figure out if it’s possible. All your sketches needs to be defined in the 3d part as your showing.
The alternative would be to make 3routes and include planes to make them parralel and dimension the routes manually to the plane. More work but no deriving needed.
