Hi All,
I'm trying to author a custom hose style to my read/write library, but when i go to select hose as the type, it's not on the list?
Any help with this would be much appreciated!
Lewis
Solved by cbenner. Go to Solution.
If I remember correctly, its how your hose model is made (structure in browser tree). Even pipe is not listed in the listing.. @cbenner am I correct or just not this morning?
Update: See I already approved myself wrong this morning.. @Lewis.Young have you created an iPart for your hose/pipe part before authoring? It is required.. Once you do that you'll see the options in that pull-down list.
Mark Lancaster
& Autodesk Services MarketPlace Provider
There are also very specific parameters that need to be present in the ipart table for any tube & pipe conduit, whether it is rigid pipe or flexible hose. Please refer to the >>Handout for my T&P class<< from AU2014, there is a section in there on authoring conduit. Hopefully it will be of some help.
Good luck!
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I've published the part successfully, however i've come across another small problem...
So i've made a new tube & pipe style that uses the newly published part, but when i populate a route, the resulting hose goes back to default black rubber colour.
When i made the ipart, i changed the "rubber-black" appearance to a red colour and re-named it to "rubber - red", but this doesn't seem to have any effect?
I'm sure i'm doing something wrong, but i have no idea what it is :S
Lewis
Could you post a screen shot of the T&P style page? Maybe there are some clues in there.
Chris Benner
While getting the screenshot i think i've noticed the problem... I'm assuming its because i have the component appearance set to "As Material"?
Your handout is now giving a 404 error, is there a new link please?
Not sure what AU handout @cbenner posted above but go here https://www.autodesk.com/autodesk-university/au-online/profile?code=HcXYj5YQymErPYI%2FqiUl6A%3D%3D&_... and look at all of his AU classes.
Mark Lancaster
One of my classes had the wrong information attached to it on the AU website, and Autodesk were going to fix it,.... looks like I need to check into this. Thanks for the heads up.
Chris Benner
