Inventor Forum
Trying to rotate a sketch around the entire object
4 REPLIES 4
369 Views, 4 Replies
I'm sorry if the title is not very helpful, but I will try to explain to the best of my ability.
I am trying to create the teeth shown in my hand-drawn sketch, as pictured. However, I do not want to have to create every single tooth on this piece. Is there a way to make one, and have it revolve around the object? This would save me tons of time, as this project is due this Friday. Screenshot_1.pngIMG_4988.jpg
4 REPLIES 4
SBix26
Circular Pattern is the tool you're looking for.
Sam B
Inventor Pro 2019.3 | Windows 7 SP1
LinkedIn
in reply to: SBix26
Thank you for your answer,
however, it won't let me extrude these features. Any advice?Screenshot_2.png
rhasell
Hi
Create and extrude a single tooth.
Then using the Circular Pattern tool, pattern the solid (Tooth Extrusion) around the sprocket.
There are many ways to model things in Inventor, some methods are just a bit better than others, and patterning the 3D object IMO is better than patterning the sketches.
Reg
2025.1.2
Please Accept as a solution / Kudos
in reply to: rhasell
Thank you so much!!!!
