- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi !
I'm working for an association where I have to 3D model some parts that people have broken, to repair it. Like someone can have a piece of a toaster that broke and I'll have to model it to replace the broken part.
Since about a week now I'm kinda stuck on this. It's a handle for lawnmower.
So I've took a picture and tried to model it using a picture, for that part I had no issue.
Now I have some blocks who are the right size, right curve and all, the issue is to "dig" the lower size of those to make it curved (like half a tube).
So I tried making an extrusion and using the "bend part" function. I thought I would be able to make an extrusion, bend it then make it a cut instead of a solid.
It does work as expected, the issue is that it bends everything. I thought I could select an extrusion to bend it but the function seems to bend all parts without distinction.
I tried searching and searching but I'm not sure I'm using the right keywords.
I'm conscious I probably am not using the right method at all.
Anyway, here's the project and pictures of the handle I have to model.
Thank you in advance for any answer.
P.S : sorry I do feel like I explained myself poorly, my native language isn't english, habitually I'm better at expressing myself but here the vocabulary here gets too technical for me.
