Inventor Forum
Tree node name diferent file name
1 REPLY 1
Leonardo_Czuy
81 Views, 1 Reply
Hello everyone,
I was copying and renaming some model files with Design Assist, but I have a little problem. The file name in the Tree node is different from the actual file name. How can I fix this?
1 REPLY 1
SBix26
in reply to: Leonardo_Czuy
In the model browser ("tree") you are seeing the Display Name of the file.  By default, the Display Name is set to the file name, but this can be changed by any user.  If you open the part file, what is the name at the top of the browser?  If it is not the file name, then edit it (slow double click), select all and delete, then Enter.  This will reset it to match the file name.
Sam B
Inventor Pro 2025.0.1 | Windows 11 Home 23H2
