Transparency adjustment in assembly
ESSInventor
ESSInventor
I can make a part within an assembly transparent by using the right mouse button and choosing transparency.  Is there any way to adjust the percentage of transparency applied? I want to decrease the amount and make it a little less transparent...
mcgyvr
tools.. application options.. display tab and change the "% opaque" in the inactive component appearance section..
ESSInventor
If it were a snake it would have bit me....  Smiley Frustrated    Thanks
mcgyvr
Don't feel too bad.. I think its not very intuitive to have it adjusted by something called "inactive component %" as making a part transparent doesn't make it "inactive"..
Thats the same setting for when you edit a part in an assembly it turns all other parts to that opacity %..
IMO I would have made a new setting for it or changed the title to "inactive/transparent component" to make it clearer to its intent..
Why the inactive component appearance transparency changes suddenly between 66% to 67% opaque.
When at 66% the inactive components are transparent but when we change to 67% the inactive components transparency changes suddenly to opaque.
There is no gradual changes in transparency.
Is there any settings for this issue.
Please Advice. Thanks
M.L.Kuselan
SEC_MECH
I have the same issue by my step change happens at 99%.
At 99% the part is virtually invisible but at 100% it is solid.
My part material is Generic/Smooth White and I am using the Grey Room IBL.
