Transfer Content Center Library from Server to Desktop
ThomasRambach
Advisor Advisor
Message 1 of 8
ThomasRambach
I'm trying to transfer a Vault server based Content Library to Desktop Content but the dialog keeps appearing as empty. What would prevent it from being available for import?
Replies (7)
Message 2 of 8
Ron_Jones1122
Are you logged into the Vault?  Is the content center set to read only?
Ron Jones
Engagement Manager
Blog
LinkedIn
Message 3 of 8
johnsonshiue
Hi! Could you take a look at the following page and see if it applies to your case?
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
Many thanks!
Software Test Engineer
Message 4 of 8
ThomasRambach
I'm trying to create a local desktop content copy of the default Content Center Libraries, so yes they are read-only. I wish Autodesk would just provide a direct download link for the idcl files.
Message 5 of 8
Mark.Lancaster
@ThomasRambach
The library transfer (desktop to Vault or Vault to desktop) only works on custom read/write content center libraries.  In this case you'll need to use the Inventor installation media to install the out-of-box content center libraries.
Mark Lancaster
Message 6 of 8
ThomasRambach
I figured it out. I'm not sure why Autodesk has downloads for server based content but desktop content you need the installation media. It's convoluted.
Message 7 of 8
cdavisX3WET
I'm getting the same results in 2026.2.  Does anybody know what this fix is?
Message 8 of 8
Roman_Vesely
Hi ThomasRambachcdavisX3WET
Transfer wizard tool is designed to work with Read Write libraries, it's not working with Read Only libraries.
Other thing why you can't see any library in the list could be the fact, that all Libraries are available on target already.
Regards
 Roman
Roman Vesely
Inventor - Principal QA Engineer
