Hi everyone!
I have recently started using Inventor, and I have been mostly modifying existing parts (modelled by other people) to match the changes my company needs.
I have also managed to start a part from scratch and develop it to the level of detail I see on the models I already have handy on my company's library. I think it is a quick way of learning the software for someone with no previous experience like me.
But now I have a challenge: There is a Torus item that was developed by a 3rd party, and they did not use Inventor to make it. They sent me a .STEP file that I can load into Inventor, but there's no way (or it exceeds my poor knowledge) to change parts of this piece.
Therefore, I have two options:
1. To "convert" the .STEP file into a fully functional Inventor model. Can this be done?
2. To start the Torus from scratch, which it's my preferred one, but due to the time limitations I have and my knowledge being far from good, I can't seem to be able to do it. Which tools and steps would you use to recreate a complex model such as the attached one, in the most accurate way possible?
The way I started was by creating an Inventor drawing which I was using to get all the dimensions I need to recreate the part, but like I said, it turned a bit complicated for me.
I would appreciate any idea on how to accomplish any of the two options.
Cheers,
Fabi
Solved by SBix26. Go to Solution.
So don't worry able copying perfectly.
Design it the way you need it.
It'll need certify anyway.
