Hi everyone!
I have recently started using Inventor, and I have been mostly modifying existing parts (modelled by other people) to match the changes my company needs.
I have also managed to start a part from scratch and develop it to the level of detail I see on the models I already have handy on my company's library. I think it is a quick way of learning the software for someone with no previous experience like me.
But now I have a challenge: There is a Torus item that was developed by a 3rd party, and they did not use Inventor to make it. They sent me a .STEP file that I can load into Inventor, but there's no way (or it exceeds my poor knowledge) to change parts of this piece.
Therefore, I have two options:
1. To "convert" the .STEP file into a fully functional Inventor model. Can this be done?
2. To start the Torus from scratch, which it's my preferred one, but due to the time limitations I have and my knowledge being far from good, I can't seem to be able to do it. Which tools and steps would you use to recreate a complex model such as the attached one, in the most accurate way possible?
The way I started was by creating an Inventor drawing which I was using to get all the dimensions I need to recreate the part, but like I said, it turned a bit complicated for me.
I would appreciate any idea on how to accomplish any of the two options.
Cheers,
Fabi
Solved by SBix26. Go to Solution.
step file aka "dumb base solid"..No features. There is this tool you could try:
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=9172877436288348979&appLang=en&os=Win64
Ad2: look at the geometry and write down on a piece of paper what simple elements this geometry consists of in turn. Note - you can't think about Inventor (or any other program). Forget about modeling - just think about it and write down on a piece of paper what solids (or their fragments) you see in this file.
Only once you have listed all the components, start thinking about how to make the individual features in Inventor. This is not complex geometry. This is a large number of simple geometries in one file (Extrude, Revolve, Hole, Fillet).
Kacper Suchomski
Hi! This part should not be too difficult to model (close to 95% fidelity). From a 3D feature-based parametric modeling perspective, one should remove as much detail (fillets, holes, markings) as possible to begin with, regardless of the CAD tool.
It should start with a hollowed torus. The lower portion does not look like a precise torus. It might be a revolved spline or some sort. The pocket in the middle looks like a triangular extrusion cut. Then more fillets were added afterwards. My estimate is that this part could be done within 20~30 features. It is not trivial but it should be highly doable in any 3D solid modeling CAD system like Inventor and Fusion.
Many thanks!
But you got the list of tools in my post. You don't have to look for them anymore. You do have to identify where these operations occur on the model.
And as for accuracy, it's enough to use the measurement tools to define the parameters as in the original.
Kacper Suchomski
Are you are hoping that someone will do it for you? If so, remember we have our own jobs and we are not getting paid to do your work... Just please keep that in mind. Yes, on little things we can easily whip out a solution, or make our own representation, but to take the time and digest and spend the time to do a complete re-design will likely not happen, unless someone just wants to lol.
Can you not reach out to the previous group and get the actual model. Then, if say it was done in XYZ software, get a trial software, then recreate it step by step? Maybe XYZ software doesn't have a trial version though.
The STEP file you posted says it was created by Pro/E. I did some measuring in the model and found that it will be very difficult to re-create-- edges and faces that I would expect to be circular are not, so to reproduce it exactly will be a very, very tedious and time-consuming task!
Sam B
Inventor Pro 2025.1 | Windows 11 Home 23H2
Until we know where you stand and what you are struggling with, we cannot help you.
If you want further advice, you need to be specific.
What have you done? Where have you stopped? What are you thinking about? What are you considering and planning?
Kacper Suchomski
From the marking on the part, it is a lifting device "WLL 10T".
Any modification, change will require PEng certification. Or else if it fail, you will be responsible.
What do you want to change?
Don't think you can make a "perfect" match" since the model is not "perfect".
Make drawing from the model and check all the dimensions.
