Hi all, the design office I work in has just updated from Inventor 2016 to 2020, which has most notably improved our ability to work with and consume parts that either contain, or are entirely made up of, mesh features.
My question - is it possible to toggle the visibility of the mesh features of all the child parts, from within the top-level assembly?
For example, an assembly I am working with may contain 100 parts, 80 of which contain both solid bodies and mesh features. Is there an out-of-the-box command (similar to View-Object Visibility-Construction Surfaces ), where I can hide every mesh feature in every child part/assembly in a single operation? The mesh feature is always an exact duplicate of the solid body in terms of shape etc.
The reason I want to be able to do this is two-fold:
- I want to be able to keep my Visual Style as "Shaded with Edges" (however in doing so, the graphics card has to work much harder to display the triangular facelets resulting in slower performance)
- I want to ensure any constraints made between parts are between the solid bodies, not the mesh by accident.
- I DONT want to have to edit each part individually to turn the mesh off
We receive and work with lots of third-party supplied files in JT format etc to use as reference geometry, which we then design around. We will implement ways of cleaner conversions in future to ensure mesh features are not imported if they are unnecessary, but for the short to medium term we have hundreds of thousands if not millions of files that contain both solid bodies and mesh features that we need to be able to work with efficiently.
I have turned the Help documentation and this forum upside down looking for a way to do this, but can't find one. I have attached some example images which I hope clarify the above.
If anyone knows how to do this, or has already developed ilogic or a macro that would do the same job, that would be much appreciated......
