Toggle 'Reference' BOM type with Model states.
andrewdroth
Advisor Advisor
andrewdroth
I just want to confirm that this isn't possible before making an idea station post.
Ideally I would be able to switch one assembly to 'reference' BOM type in an assembly using model states without that assembly reverting to 'ref' in the others.
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
Frederick_Law
I believe it work in assembly with model state.
In assembly, on browser, right click the part/subassembly -> BOM Structure
Model State will remember that.
The one in Document Setting doesn't work.
johnsonshiue
Hi Andrew,
Yes, for instance-level override, it is supported as Frederick indicated. But, no if you are looking for the default BOM structure property in the Doc settings. Also, the instance-level BOM structure override is only available to change in the Model State within the hosting assembly not the nested-level Model States.
Many thanks!
Software Test Engineer
