title block update
title block update
sei.bun
title block update
sei.bun
Hello everyone.
After the title block style is changed, when I using the Drawing Resource Transfer Wizardimage.png to uniformly change to the new version of the title block, the line type set to a dashed border appears as a solid line (when you click on the property of that border line, you can see that it is marked as a dashed line, but Shown as a solid line). Nothing moved, just click to confirm and it will show up as a dashed line. Does anyone know what the problem is?
Please click the link below to view the details.
https://autode.sk/3pYuFPv
Many thanks.
johnsonshiue
Hi! The behavior does not look right to me. It could be a bug. If possible, please share the files (the idw template and the source idw file) with me directly, johnson.shiue@autodesk.com. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
sei.bun
Thank you,
The definition file of layer is now acadiso.lin not the inventor layer file.
I loaded some layers in InvISO.lin. When I select the overlapping layers in acadiso.lin and InvISO.lin (e.g. HIDDEN2). It occurs same issue.
However when I select the layer which is not included in acadiso.lin(e.g. DASHED_SPACE). There is no more issue occurs.
