Using inventor 2021 the Revision tag is not displaying a revision level at all, trying to over ride the information using the edit doesnt save the override when hitting OK button. I created a revision table first before adding the Revision tag. I have tried using Letters instead of numbers for the Revision with zero luck. i have also tried changing the iproperties custom revision No and also the Project revision and nothing changes.
I have attached a JPEG of the screen shot of the sheet that im attempting to revise and the Revision Tag with its edit feature open. in the bottom of the image you can see the Revision Table.
