Title Block does not Dock in corner
Vagulus
Message 1 of 10
Vagulus
Why does this titleblock insert some distance from the border of the drawing?
How do I correct this?
"If you can't explain it to a six-year-old,
you don't understand it yourself"
Albert Einstein
Replies (9)
Message 2 of 10
mflayler
You need to build a border in Inventor, don't try to bring in AutoCAD ones.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 3 of 10
Vagulus
Thanks, Mark, but I don't use AutoCAD Smiley Frustrated
This Template was based on the am_din.dwg template in Inventor 2015.
Albert Einstein
Message 4 of 10
Frank-Oosterwaal
Look at the screencast.
The title block aligns to the default border, not to your autocad block.
Change it and it will align.
Edit: I agree with Mark though, better build it in Inventor.
Message 5 of 10
mflayler
the am in am_din is AutoCAD Mechanical.  Try using the Inventor DIN.idw and copy in your titleblock there.  You will probably have better performance overall.
Message 6 of 10
Vagulus
Thanks for taking the trouble of doing that screencast but, sadly, it does not help.
It is too small for me to be able to see what you are doing, and I can't find a way to enlarge it.  Also, there is no audio,
I just cannot make out what you have done.
Albert Einstein
Message 7 of 10
mdavis22569
Mike Davis
Message 8 of 10
Vagulus
Thanks, Mark, but when I use DIN.idw how do I change the format to A4?  Trying to select from available formats does nothing.
The first things appears to be to get an A4 Portrait format, then I can think about a border, then I can think about a titleblock.
Is that the right track?
Albert Einstein
Message 9 of 10
Vagulus
Aaahh! ... the obvious again. 😞
Albert Einstein
Message 10 of 10
Vagulus
Thanks for that.  Once I got to see what you did (thanks Mark) that worked fine.
Albert Einstein
