Inventor Forum
Timeout Option
16 REPLIES 16
Message 1 of 17
807 Views, 16 Replies
Timeout Option
We are trying to setup a timeout without much luck. Here is what we have:
Options File(adskflex.opt)
TIMEOUT 1800
License File
VENDOR adskflex port=2080 [options=]/C:\Program Files\Autodesk Network License Manager\License
The options file is stored in the same location as the License File. What are we doing wrong?
16 REPLIES 16
Message 2 of 17
mflayler
Seems like your syntax is wrong:
Should be:
TIMEOUT autodeskfeaturecodehere 1800
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 3 of 17
We tried earlier using the autodesk feature code, but no luck. We just tried using the TIMEOUTALL, but still no luck.
TIMEOUTALL 1800
We think it is something with the path. The "sample" instructions are confusing at best.
Message 4 of 17
Are you using License file or Service in FLex?
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
AIP 2008 SP3, AIP 2009-SP2, IV2010 ProPcCillin AV
AMD 64 x2 3.0 Ghz, 8GB RAM GeForce 9800GT 512MB
XP Pro SP3, XP Pro64 SP2, Windows XP Silver Theme
http://teknigroup.com
Message 5 of 17
We need another example of how to setup the path in the license file to point to the options file. Again, the sample given in the help is not getting us anywhere. Any help will be greatly appreciated.
Message 6 of 17
License File
Message 7 of 17
Use Service. See attached.
Message 8 of 17
Sorry, we are using "Configuring using Services".
Message 9 of 17
That is how we have it setup. What syntax do we enter in the license file?
Message 10 of 17
Screen Shot 2
Message 11 of 17
Screen Shot 3. This is the one we need help putting together.
Message 12 of 17
The instructions read "Add the path to the options file in the license file as the fourth field on the VENDOR line for the application's vendor daemon." What do they mean by "fourth field"? This is a text file so it is hard to imagine what they mean by field.
Message 13 of 17
We figured out where the path to options go in the license file. Now, how can we setup our option to timeout every user except two specific users? Is that possible?
Message 14 of 17
Where did you find these "instructions" ??
Try this link: http://www.lancs.ac.uk/staff/kevin/flexlm/chap6.htm
Message 15 of 17
See the link I posted...
Message 16 of 17
The way we read the documentation we can not timeout specific users. Are we reading this correctly? We appreciate all your help.
Message 17 of 17
Sorry, but i'm buried at the moment. Did you know there's a discussion group
strickly for network license issues?
autodesk.autocad.network
