Hi guys,
There has been a few mentioning about the thumbnail views showing wrong orientation in recent past. The suggestion had been made to change the default settings in Save tub to Active Window on Save. But it doesn't work for the most of the time.
If the model is based on Derived Components - every time the assembly is saved and closed - associated parts preview image turns into something different. But that's half of the problem. Second part of it is that when Linking Parameters from another file - one cannot verify that the right file is picked by using Thumbnail preview window. Just as it is shown on the attached image. The same is true for the Design Assistance! The preview window is blank! There couple of questions I would like to ask:
1. Can anyone verify the same behavior?
2. If Yes - is it Windows 10 related one or IV2018?
3. Is there any solution to rectify the problem? Apart of using a pencil and a piece of paper to track down the parts?
Thanks in advance,
Igor.
