- Mute
- Permalink
- Report
I'm very new to Inventor (have worked with other modelling softwares) so I still don't quite understand how to create a physical thread versus a "visual" or cosmetic thread. I'm currently modelling a supressor prop (which I will 3D print in plastic) for an airsoft gun and am making two parts 1) the supressor, with a threaded hole to stick the barrel into and
2) an adapter, essentially a cylinder with a hollow smooth inside and a threaded outside which will fit over the unthreaded barrel of the airsoft pistol and allow for me to use the threads. My confusion is that, after exporting my objects as STL files, the threads do not appear, despite my using the hole-> thread command and thread commands. Could anyone explain how to get physical threads for 3D printing. Threads are ANSI Unified Screw Threads 11/16-12 UN 2B and 2A respectively.
