Now i'm making a bushing for a grinder and the threaded part for the bushing is an ACME thread. I noticed that you can not make an ACME thread in inventor so does anyone have a solution for that? Should i just call it out in a not that the thread is an ACME thread?
Solved by karthur1. Go to Solution.
You can do it with a note. Probably the quickest easiest if you are just going to do the one thread. If you want to add it to your "threads", here is a link that includes the .xls file for ACME profile. Sort of depends on what your needs are.
Good Luck,
Kirk
@Anonymous As much as I hate to plug Inventor's "little brother".... have you ever used Fusion 360? It's a 3D modeler similar to Inventor, but newer and shinier. One of the things I know it does better is actually model the threads on parts. You might consider modeling this part with the ACME threads in Fusion, and then importing it back into Inventor? Otherwise, I would just use a note. Actually creating the geometry is possible, and definitely "mechanically cool"... but can be time consuming and probably isn't necessary unless you need the geometry to for simulation of some sort.
This is just my opinion. Others may have different ideas.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
