THREAD.XLS is empty
THREAD.XLS is empty
Message 1 of 11
THREAD.XLS is empty
i'm on Inventor 2017.
i'm struggling to get M13x1.0 thread. i believe it's not standard. but i tried to specify on the Thread.xls, it doesn't work.
i tried to edit the thread.xls, it's empty. not a single data in it.
i tried getting it from somewhere in this forum and replace it, i found out that the inventor doesn't show the m13 x 1.0 as well too.
help needed here.
thanks,
regards,
CB Lim
Replies (10)
Message 2 of 11
axel.henriquez
In order to add any custom thread please follow this suggestion http://autode.sk/2a0mJ82, For more info, see Customize thread designation in thread data spreadsheet
Axel Henriquez
Message 3 of 11
It does not work.
Because my Thread.XLS is empty, I tried downloading someone else copy.
And I put in the numbers I wanted.. and it's still not working. I plugged in
M13x1.0
Message 4 of 11
added m13 x 1.0threadxls.jpg, initially the file was empty, i copy and overwrite the thread.xls from others i fetch from the internet
but not shown below when i tried.
Message 5 of 11
SBix26
One possibility is that you are not changing the correct file.  In your active project, where is Folder Options > Design Data pointing?  If it is 'Default', where is Application Options > File > Design Data pointing?  Under that Design Data folder (in the \XLS\<language> subfolder) is where you will find the Thread.xls file that Inventor is using.
Hope that helps,
Sam B
Inventor Professional 2017 R2
Vault Basic 2017
Windows 7 Enterprise 64-bit, SP1
Message 6 of 11
mikegreslick6607
I also think that you can't change the styles on the fly and expect them to immediately update. I think (someone correct me if I'm wrong) that you have to restart Inventor before the changes kick in.
Message 7 of 11
SBix26
Yes.  I assumed that went without saying, but probably a poor assumption.  Thanks for saying it!
Sam B
Vault Basic 2017
Inventor Certified Professional
Message 8 of 11
I'm aware of that....
A poor assumption indeed
Message 9 of 11
SBix26
What are you aware of, and which assumption is the poor one?
Sam B
Vault Basic 2017
Message 10 of 11
blair
What version of Excel are you using?
Delta Tau Chi ΔΤΧ
Message 11 of 11
I'm aware of that I need to shut down the inventor before making changes
into Thread.XLS
but
1) It's empty to begin with
2) Even if I use the file from someone else, it's still the same
3) I tried adding extra thread into the file and it's not showing up in
inventor.
4) Yes I closed inventor everytime i try to make changes. Its still not
showing.
