This auto rotate thing. Please tell me there is a way to turn it off. (see post)
machiel.veldkamp
Message 1 of 35
machiel.veldkamp
So in the video I uploaded you can see me in a sketch environment. When selecting a new or old sketch Inventor now autorotates and zooms out to let you select one of the origin planes. This only happens when there are 0 planes visible.
I DON"T WANT THIS!~!!!!!!!
Please please please tell me there is a way to make this 'function' disappear.
___________________________
Replies (34)
Message 2 of 35
mdavis22569
Turn off the auto look at in application options
Mike Davis
Message 3 of 35
machiel.veldkamp
Yeah that's not it. I have that turned off for years.
This is a 'new' function.
Message 4 of 35
mdavis22569
hmmmm
 I don't have this issue ...  what version of IV?   All of the updates installed?
Mike Davis
Message 5 of 35
machiel.veldkamp
IV 2016 SP2 all updates installed.
This is particurly the case in .ipt's when trying to select a NEW SKETCH with NO PLANES VISIBLE.
Message 6 of 35
mdavis22569
Can you share it ..
Mike Davis
Message 7 of 35
machiel.veldkamp
Can I share what?
If you make an .IPT with a couple of sketches with the planes (incl. origin planes) OFF. You should get the same result.
Message 8 of 35
Frank-Oosterwaal
Yeah this happens only when there's no plane visible and there's no selection made.
So first select the face of the body or the plane in the design tree before you hit "create sketch".
By my understanding you can't turn it off.
Message 9 of 35
mdavis22569
maybe I'm missing something
Mike Davis
Message 10 of 35
RobSinglehurst
I think this is probably new behaviour with IV2016?
When creating a new sketch (you were doing this in your video - you weren't selecting a sketch), until you have a solid in the ipt then I think this is how it works. It's not something I've really noticed until you mentioned it. Perhaps just create a "dummy" solid in the ipt and leave it visible to prevent this from happening?
Not ideal I know but a fairly easy workaround.
Cheers,
--Rob
Inventor 2024.2
Message 11 of 35
mdavis22569
my screencast is in 2016 ... no solids
Mike Davis
Message 12 of 35
RobSinglehurst
Hi Michael,
Were you creating new sketches or selecting already existing sketches? I think it is when creating new sketches (that's what the original poster was doing in the screencast) in a ipt without solids that you get this behaviour.
Cheers,
--Rob
Inventor 2024.2
Message 13 of 35
mdavis22569
new ..
I just offset a plane and did a new on ...
Mike Davis
Message 14 of 35
machiel.veldkamp
I have a ipt that I can share for a bit. This is a typical Skeleton for us.
https://dl.dropboxusercontent.com/u/892935/1-16P0201-001.ipt
Message 15 of 35
RobSinglehurst
Hi Michael,
This is what I'm seeing,
Cheers,
--Rob
Inventor 2024.2
Message 16 of 35
machiel.veldkamp
YES that. It drives me bonkers
Message 17 of 35
RobSinglehurst
I don't tend to work in a ipt without a solid, often I will have derived in a solid. I can only suggest leaving a workplane turned on perhaps.
It should really have a setting in the Options > Sketch tab.
Cheers,
--Rob
Inventor 2024.2
Message 18 of 35
mdavis22569
@RobSinglehurst @machiel.veldkamp
Gotcha .... now I see what you're talking about
this is probably a bug that someone from Autodesk needs to record
Mike Davis
Message 19 of 35
mdavis22569
hmmm does it in 2017 too
Mike Davis
Message 20 of 35
machiel.veldkamp
Right. How can I report a bug?
