Thickness of lines in drawings
Message 1 of 8
I have created a circular mesh and need to make the lines thinner for cosmetic purposes in the drawing. Is it a case of picking each line and adjusting the line weight or is there a method of adjusting the line weight for the entire object in one hit.
Please see the attachment.
Any suggestions appreciated.
Replies (7)
Message 2 of 8
Thomas_Savage
In your drawing go to:
Tools = Application options = Drawing, you will see Line weight display section, and click settings.
There you will be able to change line weight.
Thomas.
Thomas Savage
Design Engineer
Message 3 of 8
Thanks Thomas
If i do this then wont this change all the line weights,i only wish to change the lineweight for the mesh.In Autocad its an easy task just by allocating a specific layer and lineweight thickness to the part.
Message 4 of 8
Thomas_Savage
I have added a screencast so you can see how to change the line weight on a view.
Do this to which ever view you want to change the line weight on. And the other views line weight won't change.
Hope this helps.
Thomas.
Thomas Savage
Design Engineer
Message 5 of 8
Thomas_Savage
I have also done a screencast for using a selection box to select certain lines in a view.
So you don't have to change all the lines in a view. Just the ones you select.
I also changed the colour of the lines ,so you can see what lines i changed better.
Thomas.
Thomas Savage
Design Engineer
Message 6 of 8
Thanks Thomas
This is what i was looking for.
Regards
Message 7 of 8
SBix26
You can also use the Style and Standard Editor to create a new layer and define it how you want.  Then select the lines and change the layer to your custom one.
Sam B
Inventor Professional 2018.1.2
Vault Workgroup 2018.0
Windows 7 Enterprise 64-bit, SP1
Message 8 of 8
Thank you.  Very helpful.
