thicken/offset not straight
Message 1 of 38
when I try to thick my surface that i created with loft I cant get the green line straight on the circle  >>>   pic attachment below
Replies (37)
Message 2 of 38
mwighton
You want the loft edge to match the green line?
Did this post help out? Hope it did.
If so please use the 'Accept as Solution' or 'Kudos' Button below.
God Bless
Mwighton
Message 3 of 38
JDMather
Attach your *.ipt file here that goes with the pretty picture.
Message 4 of 38
here is my IPT file.
Message 5 of 38
mwighton
This problem is happening because when you make create the surface thickness the program is taking the thickness perpendicular to the surface and since the surface is at an angle to the circle the edge doesn't match up with the circle.
God Bless
Mwighton
Message 6 of 38
mwighton
I was able to get what I think you were looking for, but I did not use the original surface.
God Bless
Mwighton
Message 7 of 38
do you know how to resolve the issue then?
Message 8 of 38
mwighton
Since you want the edges to be seamless, the best way would be to just create a solid loft, as my file has.
God Bless
Mwighton
Message 9 of 38
then i get an error  >>> picture attachment below.
Message 10 of 38
mwighton
For a solid loft you will need to create sketches first.
God Bless
Mwighton
Message 11 of 38
JDMather
How will this part(s?) be manufactured.
What is the material?
The manufacturing process determines how this part(s) should be modeled.
Message 12 of 38
well, how do I suppose to create those sketches because when I create a sketch then it still selects the edges. I just can't figure it out.
p.s: thanks for all the help!
Message 13 of 38
JDMather
Your sketches are not constrained and the entire model is poorly done.
Once I know the manufacturing process - someone can demonstrate how it should be modeled.
Message 14 of 38
mwighton
When in the loft command click the 'selections' window and then click on the sketch in the browser, from here you will need to select the area for which the loft will take place.
Repeat again but select the second sketch and area corresponding to that sketch.
God Bless
Mwighton
Message 15 of 38
JDmather, this is not getting manurfactured and the material should just be stainless steel because no need of manurfacturing. its a part for a gas turbine and after we have to put it all togheter and simulate it. im still a student and working with autocad isnt my greatest ability. today was also the day i firstly worked with loft.
mwighton, thnx, i will try that out.
Message 16 of 38
hossaiy
if it helps, here is another way of doing what i think you are trying to achieve (see attached "problem_a.ipt". Basically, i added one sketch ("sketch7"), used that to create "LoftSrf2" & Then used this loft and "LoftSrf1" (which you already created) as input to "Sculpt1".
I noticed Mwighton gave you one solution, but that seems to have uncovered a problem (looks like a bug), which may cause problems in down-stream features. We will take a closer look at that, but just so you can see the weirdness, here is a half section view of the model "problem_new.ipt":
Hope it helps,
Yacoub Hossain
Message 17 of 38
JDMather
Here is how I am starting out on re-design.
Message 18 of 38
hosaiy,
well I know what U did know but one more question.  how did u put in the 3.4 dimension? because I get this >>>>  picture in attachment
Message 19 of 38
hi,
I got the problem that I have a transparant "freeform" and I have no clue how to make it solid.  It's maby because of the Lofting before but I have no idea how to get arround it.
>> file below
Message 20 of 38
hossaiy
Hi michaeltje,
here is a screencast showing how i placed the 3.4 dimension,
hope it helps,
Yacoub Hossain
