There is nothing different between "with Hidden Edges" and "with Edges".
"Shaded with Edges" can't hide "Hidden Edges".
Is there any way to hide "Hidden Edges"??
Inventor Pro 2018 Build:171
Windows 10.0.15063
Solved by johnsonshiue. Go to Solution.
Hidden edges still display when the Visual Style is set to "Shaded with Hidden Edges"? Would you please share your data or a snapshot of the problem you see?
Hi! The behavior can happen either the parts are very thin and the edges on the other side are shown. Or, the components interfere with each other. Please go to Inspect -> Interference Analysis. Do you have interfered components? If yes, are they intended?
Many thanks!
@johnsonshiue wrote:Hi! The behavior can happen either the parts are very thin and the edges on the other side are shown. Or, the components interfere with each other. Please go to Inspect -> Interference Analysis. Do you have interfered components? If yes, are they intended?
Many thanks!
Thanks for your reply.
The parts are very thin.... just only 0.3mm.
But in my case, I can not tell the order of each object...
Hi! Have you checked interference? If some components are interfered, the see-through behavior would be more noticeable.
Many thanks!
Did you mean this Analyze?
Inventor Pro 2018 Build:171 Release:2018.1.1
Windows 10.0.15063
Hi! The parts are very thin. A little bit bleed through is expected unfortunately.
Many thanks!
