Inventor Forum
There is nothing different between "with Hidden Edges" and "with Edges"
7 REPLIES 7
Message 1 of 8
460 Views, 7 Replies
There is nothing different between "with Hidden Edges" and "with Edges".
"Shaded with Edges" can't hide "Hidden Edges".
Is there any way to hide "Hidden Edges"??
Inventor Pro 2018 Build:171
Windows 10.0.15063
Tags (2)
7 REPLIES 7
Message 2 of 8
EvanGu
Hidden edges still display when the Visual Style is set to "Shaded with Hidden Edges"? Would you please share your data or a snapshot of the problem you see?
Evan Gu
Inventor/Fusion QA Engineer
Message 3 of 8
in reply to: EvanGu
Sorry.
I don't know why my Screencasts was missed in the original post.
Message 4 of 8
johnsonshiue
Hi! The behavior can happen either the parts are very thin and the edges on the other side are shown. Or, the components interfere with each other. Please go to Inspect -> Interference Analysis. Do you have interfered components? If yes, are they intended?
Many thanks!
Software Test Engineer
Message 5 of 8
in reply to: johnsonshiue
Many thanks!
Thanks for your reply.
The parts are very thin.... just only 0.3mm.
But in my case, I can not tell the order of each object...Smiley Sad
Message 6 of 8
johnsonshiue
Hi! Have you checked interference? If some components are interfered, the see-through behavior would be more noticeable.
Many thanks!
Message 7 of 8
Did you mean this Analyze?
Inventor Pro 2018 Build:171 Release:2018.1.1
Windows 10.0.15063
Message 8 of 8
johnsonshiue
Hi! The parts are very thin. A little bit bleed through is expected unfortunately.
Many thanks!
