The section view get error. How to delete the section view on the idw drawing?
fshmin47
fshmin47
The section view get error. I can't find the section line to delete.
The error text:
Delete Selections: problems encountered while executing this command.
The following errors occurred during command execution:
The sketch does not contain a valid section line.
How to delete the section view?
CGBenner
@fshmin47
Hello.  Can you select the Section View directly from the browser, and delete from there?  It looks like someone edited the Section Line itself, which is controlled by a sketch, and removed part or all of it, resulting in this error.
Chris Benner
johnsonshiue
Hi! If the right-click context menu isn't available, try copying the entire sheet from this drawing and paste it to a new drawing. Can the sick section view be deleted then?
Many thanks!
Software Test Engineer
fshmin47
Yes, you're right. I found the answer on the "Inventor help" website. Now it has been done.
The answer website: https://help.autodesk.com/view/INVNTOR/2024/CHS/?caas=caas/sfdcarticles/sfdcarticles/CHS/The-sketch-...
