The operation is cancelled
0x3FA5
Message 1 of 11
0x3FA5
As per suggestion of the software, I am notifying Product Support of the problem, by posting to the Inventor forum.
Tried to rotate a part in an assembly.
I am experiencing an issue indeed, and hope the Product Support of the problem responds soon.
Replies (10)
Message 2 of 11
johnsonshiue
Hi! Many thanks for sharing the dialog! I am embarrassed to say this is the first time I see it. Are you able to reproduce the behavior? Is it file specifc?
Thanks again!
Software Test Engineer
Message 3 of 11
0x3FA5
Cannot reproduce unfortunately. This comes up absolutely randomly. It randomly appears if I try to rearrange items in the tree, or just trying to rotate a part.
No clue what can trigger that.
But the automatic suggestion to search for help  with a software issue on the forum is quite amusing 🙂
Message 4 of 11
johnsonshiue
Hi! Just a wild guess. Try cleaning up %temp%. Make sure all critical Windows updates are installed and graphics driver is updated.
Many thanks!
Message 5 of 11
0x3FA5
Yes, indeed, the temp folder is about 3.5 gb.
Deleted and will see if something changes.
Thank you!
Message 6 of 11
cosmin_andronic952G9
Hello, i'm experiencing the same issue. Did you find the solution for this?
Message 7 of 11
0x3FA5
Hi, yes, the solution suggested by johnsonshiue seems to work:
Message 8 of 11
rajivd
Community Visitor
Community Visitor
Also, I'm unable to trim a new line made in a fully constrained sketch.
Message 9 of 11
CGBenner
@rajivd
Welcome to the forum.  Are you experiencing an issue related to the original post above?  What version of Inventor are you using?
Chris Benner
Message 10 of 11
Curtis_Waguespack
@johnsonshiue, I just encountered this in Inventor 2025 and might be able to provide a reproducible data set, if it's still of interest.
Note it seems related to "drag over folders"
Message 11 of 11
johnsonshiue
Hi Curtis,
Please send the files and the steps to me at [email protected]. I would like to understand the behavior better.
Many thanks!
