Dear Inventor Forum,
I am little confused about the output result. I have created a model of a concrete joint as shown in Fig 1. Where 30 MPa wall is rigidly connected with the 12 MPa mortar (red in color) and this mortar is rigidly connected with the 55 MPa HCS (slab: yellow in color). I applied pressure loads in slab, 2.23 MPa in Z axis, 1.16 MPa in negative x axis, 0.00215 MPa in negative Y axis and a negative moment of 4.39E06 N-mm about Z axis.
Fig:1
Material properties are given as shown in Fig 2 as follows:
Fig: 2
I provided fixed support at the bottom of wall and in YZ plane of wall (where HCS is not connected). Now when I analyzed the model. The stress distribution in the model is as shown below (Fig 3):
Fig: 3
Now my doubts are:
Fig 4:
Any kind of suggestion is appreciated
-PURU
Hi @s193643 ,
Maybe this thread will give some clarification of using concrete in Inventor Analysis:
