Text on part face is flipped and backwards
Myles1
Message 1 of 8
Myles1
I am using the face of a part to create a sketch with text for an emboss.  The text is upside down and backwards.  Because I am using a part face, there is no "workplane" in the browser to us the "flip normal" option.  How can I fix this text?
Replies (7)
Message 2 of 8
Cadmanto
Sounds like the same issue as in this thread from last week.
https://forums.autodesk.com/t5/inventor-forum/inventor-model-text-mirror-problem/m-p/8497853#M726941
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 8
Sergio.D.Suárez
I think that creating a work plane by selecting the face and that it is on it, this will be the sketch plane, then this plane can be inverted to invert the text
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 4 of 8
mcgyvr
Can you share the ipt file?
Message 5 of 8
Myles1
Yes, I created a workplane on the part face and that did work.  I have never had to do that before, and as you can see from the screenshot, I am working on the positive side of all origin planes, so I am not sure why this is suddenly happening.  Another random glitch that doesn't make sense!
Message 6 of 8
Myles1
See attached file...
Message 7 of 8
mcgyvr
Just uncheck "text box" on each piece and rotate the text..
The text is simply upside down on that face..
easy fix..
This is all part of the vertical is horizontal blah blah stuff in Inventor.. Rotate it and move on..
Message 8 of 8
SBix26
From the image you posted, the text is not "flipped and backwards", it is merely upside down.  If you could Flip Normal, then it would be backwards.  As others have pointed out, simply roll it over, either by dimensioning and/or constraining the text boxes, or by turning off the text boxes and using the handles to rotate 180°.
Or, before creating the text, you could edit the sketch coordinate system and flip it 180° so that the text would default to the desired direction.
Sam B
Inventor Pro 2019.3 | Windows 7 SP1
LinkedIn
