Inventor Forum
Text Boxes in Border
4 REPLIES 4
vex
616 Views, 4 Replies
vex
Does anyone, off hand, know the procedure/call to look through text boxes in the border of an IDW?
I have something similar to
[code]
Dim oBorder As Border
Dim oTextBox As TextBoxes
For Each oTextBox In oBorder.Definition.DrawingSketch.TextBoxes
...yadda... yadda... yadda...
Next
[/code]
I'm trying to hunt down the bolded & Red portion and I'm not getting much input on the Inventor Customization forum, so I decided to try my luck here.
[code]
Next
[/code]
4 REPLIES 4
SBix26
in reply to: vex
SBix26
Just browsing the 2016 API Help, it appears to me that you want oBorder.Definition.Sketch.Textboxes.  I have not tried this, but that's what I deduce from reading the help file.
Sam B
Inventor Professional 2015 SP2
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
Sam B
vex
in reply to: SBix26
vex
Thanks Sam for responding!
I actually originally had that particular line in the code previously but it failed to actually do much of anything. Well... it did something, but it wasn't what I wanted. It output the following error:
Error in rule: Autoincrementing Zone Number Rule, in document: Auto ANSI (in).idw
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.TextBoxes'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{A907AE97-A78F-11D5-8DF8-0010B541CAA8}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Which is leading me to believe I might need to run a for loop with oSketch.TextBoxes.Count rather than the For Each
I'll report back on how it works out. If however you know the solution to the listed error, I'm all ears.
vex
in reply to: vex
vex
I'm so close I can taste it.
My program now is able to read the TextBoxes in the border. But assigning new values/text to those text boxes is causing me issues. Using
oSketch.TextBoxes.Item(i).Text = CStr(Val(sSheetNum)*8-7)
Doesn't work, as I don't think Inventor likes me rummaging through the TextBoxes without first calling the editor via
Call oBDef.Edit(oSketch)
My fear is that by calling that edit screen that way I'm not editing an Instance but the Definition... Would it be possible to edit the Instance rather than the Definition; namely something along the lines of
oBorder.Instance.Edit(oSketch)
Or is that just causing me more grief than it's worth?
Edited to add:
It also appears that it's impossible to edit an instance of this border for some reason. Is this because there's an iLogic rule associated with it now?
Edited to add:
vex
in reply to: vex
vex
And it's as I feared:
Calling the edit command results in the program operating as it should (substituting the various <X> tags to the appropriate number), however it does this by editing the definition. Something I didn't pay attention to early on, but something I figure would be an easy fix, right? Well, according to the 2010 API pdf I had printed out ages ago (I'm using INV2015), it doesn't look like it's possible. For why the Sheet lists TitleBlock as an entity, the border is not listed as an object within that parent--indeed according to the 2010 API PDF it looks like BorderDefinition is the only available call that deals with the border.
