Ceil Function not working
Im having a problem getting my equation to give me the next highest number of inches. I understand ceil wants unitess and this whole problem is based around units, but after reading other posts about this issue and trying to replicate their solutions, i am still not getting the result i need. heres the scenerio:
- I have a linked parameter "Height" which is in inches
- i need to change the length parameter of an object to be 70% larger than "Height"
- I have input into the length parameter (Height*1.70 ul)
- I want the result to be the next highest whole number
once i type "ceil" at the front of the equation, it gets highlighted red and says "Warning: Unit Specifiction Mismatched"
My result needs to be a length in inches.
Also the object whos length is determined by this formula is an angle from the content center. I am not sure if that makes any difference but I thought I would add that information. There are many default parameters for object from the content center so im thinking i could possibly have my equation in the wrong feild.
Anways, any help is appreciated!
Sandro
JDMather
Sandro
This doesn't make sense?
How would this cancel out the units.
10 inches*1.7 ul = 17 inches, not 17 ul
Your equation must be written to cancel out the units, do the ceil and then reapply the units.
When generating formulas I like to do it as I was taught in HS.
Write it out by hand in pencil and cross through units as they are canceled and show remaining units.
I remember how our HS teacher used to rant on and on about how you can't just ignor the units....
I understand that that is the issue.
I just don't know how to write the equation out.
in your equation, I want that 17in not 17ul
actually i think ive figured this out.
I wrote the equation as
(ceil((Height*1.7ul)/1in))*1in
seems to work, not sure if any of that is unnecessary, but the end result works so ill probably keep it that way.
JDMather
Looks to me like you got it.
Good job!
