Inventor Forum
Text box not Displaying "\" then capital letter
6 REPLIES 6
mark.almack
453 Views, 6 Replies
I'm trying to display a parameter (which is a file path) in a text box on a drawing, but it seems to miss out the "\" if followed by an uppercase letter. E.g. if i type "C:\Abc" in the text box, it displays "C:bc" on the drawing!
Anyone know how i can display the desired value?
6 REPLIES 6
johnsonshiue
in reply to: mark.almack
Hi Mark,
"\A" looks like a reserved keyword in the TextBox. I cannot explain the behavior. I need to check with the project team.
Many thanks!
Software Test Engineer
Xun.Zhang
Hello @mark.almack,
Try C:\\Abc\\... other than C:\Abc\.
Refer more from below link.
https://docs.microsoft.com/en-us/dotnet/standard/io/file-path-formats
Hope it helps.
Xun
Tags (1)
mark.almack
in reply to: Xun.Zhang
why has this been marked as a solution?
It's not!
I'm trying to display one of my parameters, and it is not allowing me to do so.
Why does anyone other than the author have the rights to accept as solution?
-niels-
The Author of the topic, Autodesk personnel and Expert Elite Members have the ability to mark posts as solutions.
There should've been a notification of who accepted a solution to your problem, if this was not correct then you should be able to unmark the post by clicking the 3 dots and selecting "not the solution".
Sorry i can't help with your original problem, but i hope you can get it resolved and correct the (hopefully accidental) incorrectly marked solution.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
johnsonshiue
Hi Mark,
I was the one tagging Xun's reply as the solution. I thought his explanation made sense. It seemed to work for me. I need to take a closer look. In the meantime, I am removing the solution tag from his posting.
Sorry for the confusion!
lena.talkhina
Hello there!
I am sorry I didn't see this thread earlier.
Don't hesitate to ping me in future if you need to unresolve the problem or push the report button and explain to our administrator what the concern is.
But anywhay, I wonder if you @mark.almack  found a solution finally? Don't hesitate to share with us what helped.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
