Text alignment wrong and Mirrored
Vagulus
Message 1 of 9
Vagulus
I wish to emboss some text on a part.  When I insert the text it appears misaligned and in mirror print
How to fix?  Tried every button on the Text Dialog.
"If you can't explain it to a six-year-old,
you don't understand it yourself"
Albert Einstein
Replies (8)
Message 2 of 9
Sergio.D.Suárez
Hi, try to invert the normal of the work plane
I hope it helps you solve your problem
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 of 9
Xun.Zhang
@Vagulus ,
You can also try with Geometry Text and flip the direction. Try to drawing a line first and make a Geometry text instead.
Hope it helps!
Xun
Message 4 of 9
Vagulus
Thanks Sergio and Xun, but I cannot figure out what either of you is doing.  I am using AI2018 and I cannot match Sergio's interface with mine (Sergio's being in Spanish (I assume) isn't a lot of help 😞  ) and I cannot figure out which mouse click he uses or which buttons he clicks.
I have no idea what Xun is talking about at all.
I have attached my IPT as far as it has gone.  I would like the text all on one line, upright, horizontal, formed to the face and embossed 0.5 mm.  Would one of you please slowly step me through the process.  Voice over would be great but my Spanish is not really good.  It's better than my Mandarin but not by much 🙂
Albert Einstein
Message 5 of 9
Xun.Zhang
Hello @Vagulus ,
Above two solutions are working well.
Check out the enclosed file for reference.
Hope it helps!
Xun
Message 6 of 9
Vagulus
I see the results but I still don't know what you did.
I used the 'Rotate' tool and get to here
Now I need to flip the text on the vertical axis.  How do I do that?
Albert Einstein
Message 7 of 9
Xun.Zhang
Hello @Vagulus,
Here are two videos for your reference.
1. Geometry text alignment
https://autode.sk/2uDiEUk
2. Flip normal
https://autode.sk/2CMzHHL
Hope those are help!
Xun
Message 8 of 9
Vagulus
We got there!  Thanks,  Phew!
Please, when you go to the trouble of making screencasts, which I appreciate, please take the steps slowly and distinctly.  You know what you are doing and I don't.  It is very hard to follow rapid-fire mouse clicks in a blurry screencast.
Albert Einstein
Message 9 of 9
SER4
*NOTE!
If e.g. you have a modelled feature that is already using the sketch (e.g. engraving), and you try to Flip Normal but you get an error saying something like "profiles extend outside the body", then you need to delete just the feature ONLY (do not delete consumed sketch).
Then edit your sketch so it is within the body, and finally re-apply the feature using the sketch again.
(Autodesk made a poor/weak/simplified attempt at a solution here: https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Inven...)
P.Eng. Mechanical Engineer
Dell Precision 5680 Laptop; Win11 Pro; 64GB RAM; i9-13900H CPU; Intel Iris Xe Graphics, NVIDIA RTX 3500 Ada Laptop GPU.
Vault Pro 2025.1 (30.1.63.0); Inventor Pro 2025.1.1 (241).
