If I open one of my templates and change the setting of a particular layer (linetype from continuous to dashed). Then resave template. The next time I open it, the linetype has reverted back to continuous?
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
Gilberto Binga
Facebook | LinkedIn
LOUCO POR AUTODESK
save it back to the same folder as your templates (as the template you start with) and it'll save or
save it as a template
