Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Inventor Forum
Template file - "Attempted to access an unnamed file past its end" Error
7 REPLIES 7
Message 1 of 8
edward.mAY7KQ
128 Views, 7 Replies
Hey Guys,
I created a template for one of our clients and went thru the process of Save copy as a Template once compiled and styles etc created and assigned... It saves this into the Templates directory as normal, however whenever I return to create a new drawing from this template at the New=> Template Dialogue, the following error pops up "Attempted to access an unnamed file past its end"... After which the template does not open and cannot be accessed - I open the file explicitly from the templates directory and it opens fine - all styles accounted etc... However, when accessing this from the New - Template Dialogue this error pops up... I've even tried simply copying the file into the Templates directory and low and behold the error pops up again... Is there a solution for this error..?
Tags (2)
Labels (2)
7 REPLIES 7
Message 2 of 8
CGBenner
in reply to: edward.mAY7KQ
@edward.mAY7KQ
Hello and welcome.  Are you still struggling with this?  Would it be possible to share the template file here for others to look at?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
Message 3 of 8
Hi! I would like to clarify a few things. A template has to be a static file. It cannot be opened by another application at the same time and it is changed dynamically. Also a template should not have any preexisting reference files (a drawing with a view or an assembly with a part).
Many thanks!
Software Test Engineer
Message 4 of 8
edward.mAY7KQ
in reply to: CGBenner
Unfortunately - I cannot share the template as its another company's IP...
Message 5 of 8
This template was built from scratch in the normal fashion - Its a static file, never opened by another application or altered outside of the Inventor environment.... There are also no preexisting reference files associated with the template either...
I've built quite a number of templates, and this is the only one that seems to behave like this...
Message 6 of 8
Hi Edward,
Unfortunately, it might be corrupted. I guess you will need to recreate it.
If you find out how to reproduce the corruption, please let us know asap.
Many thanks!
Message 7 of 8
Hey John -
Hope this isn't the case of having to rebuild - they do take a lot of time as they are an Inventor recreation of the Clients old AutoCAD Templates...
I can open the file explicitly with no issue or error popping up... However, as soon as I move it, copy it or 'save as a template' to the 'Templates Directory', the error occurs...??
Message 8 of 8
Hi! The behavior does not make sense to me. Please make sure all critical Windows updates are installed and the graphics driver is updated. Also clean up %temp%.
Many thanks!
