Task Scheduler - Export part to jpeg
henryjoseph9804
henryjoseph9804
Hi all,
I would like to find out about something. I currently have a bunch of assemblies & parts. I want to use task scheduler to open each part and export the home view as a jpeg.
Is this possible? If so, how could I go about setting it up correctly?
Thanks a bunch.
IV2024
johnsonshiue
Hi! Task Scheduler has a task to print iam and ipt files to PDF. Or you may want to take a look at the following discussion.
https://forums.autodesk.com/t5/inventor-programming-ilogic/batch-export-images-with-transparent-back...
Many thanks!
Software Test Engineer
