costraint recovery
costraint recovery
ambrosiPZ23D
costraint recovery
ambrosiPZ23D
Hello
I have a 45° curve in the content center created with a different model than the 90° curve,
when I replace the 90° curve with the 45° curve I lose the constraint.
I can't use the same ipt model for 45° and 90° curve.(I should change the table in the CC).
How can I avoid losing the constraint?
James_Willo
Unfortunately the two parts will not have the same internal IDs for the geometry faces so your constraints will go sick.
The only way to do this is to model one of them and then do a save as and turn that geometry into the other part so the internal IDs stay the same.
If you're using Tube & Pipe this workflow might work, but I'm not an expert on that environment.
However, you may be able to do this with iMates, but not with stock content which I think is what you're using.
James W
Inventor UX Designer
