Task Scheduler bug
Task Scheduler bug
YannickEnrico
Advisor Advisor
Task Scheduler bug
YannickEnrico
Hey there.
I was aware that Windows was known for bad timers and weird percentages - I had not expected Task Scheduler to do the same.
See attached.
I'm fairly certain it doesn't matter in regards to performance. I just wanted to inform you.
I'm using Task Scheduler to migrate all files in my vault.
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
mcgyvr
No thats a new "feature" from Autodesk..
if 100% is great then 1621622% is even better Smiley Very Happy
johnsonshiue
Hi Yannick,
This is a bug. I guess TS was too ecstatic to finish a tough task and go beyond normal. Do you see this behavior often? Is it easily reproducible?
Many thanks!
Software Test Engineer
YannickEnrico
I've only just used TS 2018 once to migrate all my files from 2017.
I used it once, but through the process, it restarted the counter a few times. That might have been when a new part of the task has started?
Some of them only went to 100%, and some of them went a little overboard to several million percent.
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
