Inventor Forum
Tangent constrain
11 REPLIES 11
Message 1 of 12
852 Views, 11 Replies
Tangent constrain
In the assembly attachment, I tried to constrain  tangent between the 2 curved parts but it isn't work properly. Does there any help please?
Thankyou,
atajabbas
Inventor 2020
Tangent constrain
Thankyou,
atajabbas
Inventor 2020
11 REPLIES 11
Message 2 of 12
gcoombridge
gcoombridge
Heres an old thread: Solved: tangent between two curved srufaces - Autodesk Community - Inventor
I couldn't get a good result though it does improve if you can align the XY Planes of the two parts.
Can you add an axis to the shackle and constrain to that or do you need full lateral movement?
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
Message 3 of 12
gcoombridge
gcoombridge
Message 4 of 12
gcoombridge
gcoombridge
Actually a translational constraint to an extruded cylindrical surface running through the thimble eye gives a more accurate representation. But it still requires an alignment of the XY planes to stop it going haywire...
Message 5 of 12
in reply to: gcoombridge
I need full lateral movement
Thank you
Thank you
Message 6 of 12
I have opened the chain example but I haven't understand how did he do the constrains? I have contacted Mr. Curtis about it and waiting his reply.
Thank you for your kindness,
atajabbas
Inventor 2020
atajabbas
Inventor 2020
Message 7 of 12
johnsonshiue
johnsonshiue
Hi! I have replied to the same question on an older thread. Please take a look at my latest reply.
https://forums.autodesk.com/t5/inventor-forum/tangent-between-two-curved-srufaces/td-p/6343122
Many thanks!
Software Test Engineer
Many thanks!
Message 8 of 12
gcoombridge
gcoombridge
I've had a look, it's very clever! Especially for an assembly created in 2002...
At each chain connection there is a point to point mate constraint at the inside of the radius (the contact point where the chain will rub.
Then there is an 30deg undirected angle constraint between an axis that goes through the point and the plane parallel with the link to an axis going through the point perpendicular to the plane of the link. Open an link and turn on all the work features then hover over the constraints in the assembly. It should be clearer then.
Notice there are no tangent constraints at all...
Message 9 of 12
Many thanks for your kind reply.
Please give me a time to understand and figure out the answer>
Again many thanks for your kindness
atajabbas
Inventor 2020
atajabbas
Inventor 2020
Message 10 of 12
Sir, how to create Extruded Cylindrical Surface?
Thank you
atajabbas
inventor 2020
Thank you
atajabbas
inventor 2020
Message 11 of 12
Sir, how is the Extruded Cylindrical Surface created? There is no tool (as it is seen to me in inventor 2020) to create extruded surface.
Thankyou,
atajabbas
Inventor 2020
Thankyou,
atajabbas
Inventor 2020
Message 12 of 12
SBix26
SBix26
Not a separate tool, it's a button in the Extrude properties panel:
Sam B
Inventor Pro 2021.2.1 | Windows 10 Home 2004
LinkedIn
Sam B
LinkedIn
