Good afternoon,
I would like to remove the adaptivity from all my T&P runs then save them as their own sub-assembly. I've tried unchecking the "adaptivity" check box in the iproperties only to have the check reappear. Any thoughts?
Good afternoon,
Hello , just grab the run from the model tree and drop it in the display window. Then , from iProperties change XYZ position to match the original position.
Hope it helps
Hope it helps
@Anonymous
Hi,.. can I ask what it is you're trying to accomplish by removing the adaptivity? That might help offer a good suggestion.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
@Anonymous
Chris Benner
@Anonymous Great, Thank you!
@CGBennerWe use T&P extensively within our ~1200instance/5000occurance machines (see image). A few reasons I prefer to identify T&P runs as sub-assemblies are:
1. the ability to change i-properties of each tube/hose (i.e. unique part numbers)
2. the ability to save each T&P sub-assembly outside of the top-level T&P assembly
It's difficult to manage the top-level assembly when I'm working on one sub-assembly and a T&P reference point moves which in turn re-routes the run, adding fitting/tubing without knowing.
