Inventor Forum
Symantec endpoint protection - Inventor - Vault
5 REPLIES 5
Pavel_JDK
2141 Views, 5 Replies
does anybody have experience with Symantec endpoint protection installed with Inventor and Vault ?
I suspect Symantec to be reason of very slow openning Inventor files.
I understand it's specific problem depending on configuration, but maybe somebody know ...
Pavel
5 REPLIES 5
in reply to: Pavel_JDK
I've never heard of Symantec End Point, but if it contains Anti-Virus
software you need to go into the settings and excluded Inv files types and
folder locations
I excluded the following
"*.i??"
"c:\Program Files\Autodesk\*\*"
Work and storage folders
"C:\Documents and Settings\«name»\Application Data\Autodesk"
"C:\Documents and Settings\«name»\Local Settings\Application Data\Autodesk"
"C:\Documents and Settings\«name»\Local Settings\Temp"
"C:\Documents and Settings\All Users\Application Data\Autodesk"
"C:\Documents and Settings\All Users\Application Data\Autodesk, Inc"
I only exclude these files and folder locations from the AV's day-to-day
monitoring of my computer. I DO NOT esclude them from the weekly scan my AV
does.
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and
proving by fabricated insanity that nothing could be as mad as what passes
for ordinary living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
http://support.microsoft.com/default.aspx/kb/555375
wrote in message news:6254310@discussion.autodesk.com...
somebody know ...
Pavel
Pavel_JDK
Thanks a lot. I had set some exceptions, but not all.
Would you please tell me also about firewall ? I can see in task manager, that during opening there is still activity of process smcgui (I/O read bytes increase), which is propably firewall (as I found on web). Propably it is now the reason.
Pavel
The activity it either Inv conecting to CC/Vault &/or the Communication
Centre.
Your Firewall isn't the culprit.
Duncan
wrote in message news:6254379@discussion.autodesk.com...
is now the reason.
Pavel
Additionally (I mentioned this in a previous post somewhere, you can do the
search) turn off scanning of network drives in SEP if your Vault is on a
network server or if you pull any files off the network. The file type
exclusions will not take effect if those files are loaded from a network
path.
"Duncan Anderson"
wrote in message news:6254319@discussion.autodesk.com...
> folder locations
> "*.i??"
> Data\Autodesk"
> AV does.
> Duncan
> Hello,
> somebody know ...
> Thanks
> Pavel
If looking for other best endpoint protection software, go with enterprise.comodo.com, it is providing best software. recently I get a positive review from my friend's circle.
Technology Administrators
