Additionally (I mentioned this in a previous post somewhere, you can do the
search) turn off scanning of network drives in SEP if your Vault is on a
network server or if you pull any files off the network. The file type
exclusions will not take effect if those files are loaded from a network
path.
"Duncan Anderson"
wrote in message news:6254319@discussion.autodesk.com...
> I've never heard of Symantec End Point, but if it contains Anti-Virus
> software you need to go into the settings and excluded Inv files types and
> folder locations
> I excluded the following
> "*.i??"
> "c:\Program Files\Autodesk\*\*"
> Work and storage folders
> "C:\Documents and Settings\«name»\Application Data\Autodesk"
> "C:\Documents and Settings\«name»\Local Settings\Application
> Data\Autodesk"
> "C:\Documents and Settings\«name»\Local Settings\Temp"
> "C:\Documents and Settings\All Users\Application Data\Autodesk"
> "C:\Documents and Settings\All Users\Application Data\Autodesk, Inc"
> I only exclude these files and folder locations from the AV's day-to-day
> monitoring of my computer. I DO NOT esclude them from the weekly scan my
> AV does.
> Duncan
> "Humour ... is one man shouting gibberish in the face of authority, and
> proving by fabricated insanity that nothing could be as mad as what passes
> for ordinary living."
> (Terence 'Spike' Milligan K.B.E., 1918-2002)
> www.autodesk.co.uk/inventorjobs
> http://support.microsoft.com/default.aspx/kb/555375
> wrote in message news:6254310@discussion.autodesk.com...
> Hello,
> does anybody have experience with Symantec endpoint protection installed
> with Inventor and Vault ?
> I suspect Symantec to be reason of very slow openning Inventor files.
> I understand it's specific problem depending on configuration, but maybe
> somebody know ...
> Thanks
> Pavel
