Inventor Forum
Sweep Pick Sketch
4 REPLIES 4
jletcher
319 Views, 4 Replies
Sweep Pick Sketch
Buggy pick sketch
How it should be
Enough Said....
4 REPLIES 4
blair
in reply to: jletcher
Check that the line end-points are Coincidental. A small gap or overlap will cause the Sweep function to fail. Post the offending file if possible.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
jletcher
in reply to: blair
The No is not what I want unless I pick it, the yes is how it should work if I want it straight I pick my straight sketch if I want it Radius I pick my radius sketch.
 But as you can see Inventor does what it wants. Works in all other spots but this one and it stops me from completing my goal once again..
Works in Solid Works, Solid edge, Pro E, and 2 others...
But thanks for the reply Blair...
mpatchus
Difficult to really troubleshoot without the actual files.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
jletcher
in reply to: mpatchus
I rather you make your own only real way to troubleshoot. I have no issues but the one spot and they are all the same 100%.
 But thanks for the reply Mike..
