Check that the line end-points are Coincidental. A small gap or overlap will cause the Sweep function to fail. Post the offending file if possible.
The No is not what I want unless I pick it, the yes is how it should work if I want it straight I pick my straight sketch if I want it Radius I pick my radius sketch.
But as you can see Inventor does what it wants. Works in all other spots but this one and it stops me from completing my goal once again..
Works in Solid Works, Solid edge, Pro E, and 2 others...
But thanks for the reply Blair...
Difficult to really troubleshoot without the actual files.
I rather you make your own only real way to troubleshoot. I have no issues but the one spot and they are all the same 100%.
But thanks for the reply Mike..
