Sweep Function Help
Sweep Function Help
Sweep Function Help
Hi, I'm relatively new to autodesk inventor but I am trying to create an stl file to 3d print. Here's my problem. I'm playing around with the sweeping tool at the moment but I always seem to get an error when I try to  sweet a shape along a closed path. Would anybody know how I can fully close this path? I know I could use an offset plane and extrude a circle along one piece but is there a cleaner/more efficient way of doing this?
PaulMunford
I think that you're on the right track.
I would make this out of from-to extrusions to workplaces set at the corner angle, perhaps with a sketch block for the profile.
More steps, but more robust if you want to change sizes later.
Customer Adoption Specialist: Autodesk Informed Design
Help | Learn | Forum | Blog | Ideas | Sample content | Linkedin
