Dimensions Given for a Drawing Have Diff Dimensions from Diffrent Views-
My class was given a drawing to replicate. I printed out the PDF given, the figure is not true to size but
what puzzles me is that the base from the top view has a different length on the short edge than the
view of the drawing from the side. The side view is 1/4 inch longer, how can that be? The top view gives the length
from the center of a circle to the short edge as one inch, the mirror view looks identical and there is no way for me to be sure,
would a teacher deliberately give students drawings that aren't correct? I don't know what it is I am drawing, I am not a mechanical
engineer which makes this even more difficult.
CK
brendan.henderson
Welcome to the forum.
This is the exact purpose of a properly laid out drawing. It is to remove the assumptions you have made. You say that "the mirror view looks identical" = assumption. The end view clearly shows that the base is 2 1/4" wide, regardless of you thinking that because the holes are 1" from 1 side they should be 1" from the other side = assumption.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
BeKirra
Obviously there are some dimensions are missing. However in your excercise you are asked to replicate the model from the drawing.
You can measure the dimensions by scaling the drawing. You don't have to create the model with 100% acuate.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
IgorMir
Yes, that the recipe for a disaster - that's for sure. Such a "practice" then becomes accepted as a norm in the future. And then - everyone involved with the project will be busy flat out blaming each other for the total mess created!
Igor.
HTH
Web: www.meqc.com.au
