Sweep Function Between Two Faces
Michael_FerrisE8WSF
Message 1 of 10
Michael_FerrisE8WSF
I am trying to make a "pipe" between a vertical and horizontal surface via sweep and can not get the path right. See attached for image. Any help would be appreciated.
Accepted solutions (3)
Replies (9)
Message 2 of 10
Michael_FerrisE8WSF
its not sitting flush on the bottom plate
Message 3 of 10
CCarreiras
Hi!
Well probably You will need a 3D Sketch as path...
But without the file or more info about what you really want, we can't figure what you need.... we are not wizards to read your mind.
CCarreiras
Message 4 of 10
Michael_FerrisE8WSF
I do have a 3D sketch path and here are the files.
Message 5 of 10
CCarreiras
Here's an option:
CCarreiras
Message 6 of 10
CCarreiras
You have to apply tangent constrains in the start and end path.
Also, design the path in a way that the tube doesn't intersect himself.
CCarreiras
Message 7 of 10
Liam_Cooper
Surely by now Autodesk have the capability to select two faces and it automatically connects both ends of the pipe together, a combination between sweep and extrude but not from a sketch.
Message 8 of 10
Liam_Cooper
As an example, select each face and the program puts the missing bend in.
Message 9 of 10
johnsonshiue
Hi! This might be another case that Solid Sweep could help. Instead of sweeping a circular profile, use a sphere to sweep the path. Cut off the unwanted portion of the sphere at the start and the end.
Many thanks!
Software Test Engineer
Message 10 of 10
SBix26
You're still going to have to specify the bend radius and verify that the straight portions are coplanar.  Those are things that get taken care of in the process of creating a sweep path sketch.
Sam B
Inventor Pro 2025.1.1 | Windows 11 Home 23H2
