I´m pretty much a novice.
But i need to make grooves on a cone.
I want them to go from the narrow end to the wide end.
I need 10 of them equally spaced apart.
i have added the file where i have made contour of the grooves.
I would like if someone could teach me how.
Sincerely Unocom
Solved by kimx248w. Go to Solution.
Solved by SBix26. Go to Solution.
Solved by kacper.suchomski. Go to Solution.
Hi
Kacper Suchomski
Following up with @kacper.suchomski 's recommendations and observations, I started by fully constraining your first sketch, then created a workplane perpendicular to the cone surface, and the circle sketch on that plane to create one groove; then fillets added and all of that patterned around the cone's axis. Hope that helps.
Edit: I realized the workplane creation could be done much more simply, so replaced the video with a better one:
Sam B
Inventor Pro 2025.0.1 | Windows 11 Home 23H2
