sweep command
sweep command
Message 1 of 14
sweep command
Im trying to sweep a sketch to make a piece of wire mesh rolled up to fit inside a pipe and having problems completing it not sure of the error.
Replies (13)
Message 2 of 14
JDMather
There are at least 2 better techniques* to use for this, but Sweep should also work.
Can you Attach the *.ipt file here>
*Contoured Flange or Coil.
Message 3 of 14
leowarren34
Are you sure the sweep doesnt self intersect as it looks awfully tight between coils?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 4 of 14
blair
It looks like it's selecting the path along with the profile.
As JD posted, attached the offending file for us to look at.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 5 of 14
JDMather
@JDMather wrote:
There are at least 2 better techniques* ....
*Extrude as Surface Body and then Thicken to solid should also work.
Message 6 of 14
Awesome i will try the other methods i havent used them yet still learning the software. I drew the coil in autocad the imported it and translated it and projected the geometry so i could use the end point as a reference.
Message 7 of 14
johnsonshiue
Hi! Could you share the file here? It looks like the profile is not perpendicular to the start of the spiral path.
Many thanks!
Software Test Engineer
Message 8 of 14
I shared the font size in my last reply are they not showing?
Message 9 of 14
johnsonshiue
Hi! Sorry I missed the files! I took a quick look. The failure is about the profile sketch plane not being at the start of the spiral path. I created a new workplane and redefined the profile sketch. It works fine. Please take a look.
Many thanks!
Message 10 of 14
that worked can you explain it how you fixed that a little more
Message 11 of 14
johnsonshiue
Hi! I was literally doing exactly like I described earlier. I open the part and create a normal to path at point workplane. Then reorder the profile sketch to the bottom in the browser. Right-click on the sketch -> Redefine -> select the workplane. Sweep will work.
Many thanks!
Message 12 of 14
Is there any way you could create a screen-cast of you doing that I'm trying to make mine work like that for future times and cant get it to work on mine, i think i have a idea what your talking about in your steps.
Message 13 of 14
DFitting
Heres what I have come up with. You can define your spiral by using the Parameter ID and adjust the Pitch to get your spiral spacing.
Message 14 of 14
leowarren34
It's nice seeing parts from others perspectives, I forgot about the coil though it performs very much like a sweep when configured.
Leo Warren
